- Messages
- 116
- Likes
- 13
I thought I would show what I am doing with my install of the Taurus fan. I chose the Taurus fan because it really sucks. Sucks a lot of air through the radiator that is (don't know the CFM, sorry). I've searched high and low for a cost effective suitor to control thisTaurus fan I bought. The best method I've found to achieve my goal is using the fan control relay out of a 93-97 Volvo 850 (part number 1398845). The reason I really like this option (besides cost) is that it will run both speeds of the fan. Most of the controllers I looked at only use one speed. To run both speeds though, it requires a trigger for each speed. Enter the BMW switch. These can be found on the 96-98 318I, 95-99 318TI, and the 96-98 Z3. The other nice thing about these switches is the fact you can get it in two temp settings, depending on the thermostat you are running. One switch (part# 61318361787) has the low speed kick on at 180F, while the high kicks in at 195F. The other switch (part# 61311378073) has the low speed kick on at 195F, while the high kicks in at 210F. I run a 180 thermostat, so I went with the first switch.
EDIT: The part numbers for the BMW Sensor connector are below in BOLD (It come in pieces, and needs assembled)
#61131378412 - BMW 90 degree angle connector (Wire Housing - Black Plastic)
#61130007445 - BMW 90 degree angle green connector wires (Need 2)
#61130007446 - BMW 90 degree angle green/black connector wire (Need 1)
All of it is exceptionally cheap considering they are dealer only. I got all of it for under 10 bucks.
Update (10/7/14):
For a 180 Thermostat, use BMW part# 61318361787
For a 194 Thermostat, use BMW part# 61311378073
Here is what I've gathered so far:
I have a new stock warranty replacement (FREE) aluminum radiator , and the Taurus fan (9 dollars out the door) sitting next to it. The Taurus fan covers a good portion of the radiator. I'm thinking I will try it like this to begin with, and possibly incorporate it into the factory shroud later.
Here is the relay I am using from a 97 Volvo 850. On the Volvo, this unit located on the underside of a panel that sits directly above the fan. That may be useful to someone... I scratched my head for a bit before I realized it was there.
MORE TO COME!
I would also like to thank the author of this thread over on nastyz28.com - http://www.nastyz28.com/forum/showthread.php?t=200028 - this thread greatly aided in my decision.
Update (10/7/14):
MORE TO COME!
