- Messages
- 200
- Likes
- 0
- City
- Houston
The fenders are significantly wider. Just look at the extra sheetmetal on the edges of the headlights. The fenders provide the extra width needed to fit the long-travel suspension and wider wheels and tires. The truck is 67.3 inches wide at the front and rear tracks. The new bumpers and 11.1 inches of ground clearance give the truck an approach angle of 32.5 degrees, ramp-over angle of 24 degrees and a departure angle of 24 degrees.
Out back, the altered rear bumper now has a pair of tow hooks. The sensors and tow connectors have been changed, too. While the Ranger Raptor is wider overall, it doesn't seem like the bed's interior dimensions have been increased. There are Raptor logos on the rear fender and the tailgate.
Changes to the interior are much more subtle. The steering wheel has a stripe in the middle to denote the top position. The seats have a faux suede finish as well as modified bolsters and seat backs in order to improve comfort.
The truck's big changes come underneath the skin. The chassis, brakes and suspension have all been beefed up to better tackle rough terrain. Ford specifically says the truck is meant to "travel at high speeds off road," words we're quite happy to hear. The solid rear axle is suspended using coilovers and a Watts link setup. It provides vertical movement with very little lateral shifting. The geometry has also been changed to fit the new suspension.
The front and rear dampers are both provided by Fox Racing Shox with 46.6mm pistons both front and rear. We're curious how these compare in the real world to the Colorado ZR2's fantastic spool-valve setup. The trucks upper and lower control arms are both made from aluminum. The front and rear brakes have both increased in size. They're supported by new 17-inch wheels and a set of knobby BF Goodrich 285/70 R17 tires.
Under the hood rests a 2.0-liter twin-turbo diesel inline-four. It's mated to Ford's new 10-speed automatic, likely the same one that's found in the F-150 and the U.S. version of the Ranger. It makes 210 horsepower and 369 pound-feet of torque, more than the Colorado 2.8-liter diesel's 169 horsepower and 369 pound-feet of torque. Power hasn't been announced for the the U.S. Ranger's 2.3-liter EcoBoost turbo-four, but expect that gasoline engine to make more horsepower but significantly less torque.
We've contacted Ford about the truck's U.S. prospects, but we're not getting our hopes up. We'll update this story with any more official info.
