Welcome to Ford Ranger Forum, is this your first visit? Click the "Create Account" button now to join.
Register
User Tag List
Results 1 to 3 of 3
  1. #1
    Member #
    36
    Medals
    Join Date
    Mar 2017
    Rustenburg
    South Africa
    Posts
    3
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rep Points
    1
    2000 Explorer 5.0 V8 Connector C115 Pinout
    Guest-only advertisement. Register or Log In now!
    Hi, is there perhaps anyone that can provide me with the correct info on a 2000 Explorer 5.0 V8 as to where all the wiring on connector C115 (42 pin) needs to go. See attached pic of the connector
    I have trouble with understanding pins: 5, 15, 20, 25, 31 and 36. Connector C115 is for power in and signals out, if I'm correct? Pins: 1 (Coil packs), 8, 9, 20, 24, 25 and 36 would be 12v input and the rest of the pins would be signal, data and reset points?
Size:  78.9 KBName:  00ExplorerC115ConnectorPinOutDescription.jpg
  2. #2
    Senior Member MustangShane's Avatar
    Member #
    9
    Medals
    Earned First 100 Posts
    Join Date
    Apr 2016
    Hatu
    UT
    Posts
    116
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Rep Points
    1
    This is all you, Rick....
  3. #3
    Member #
    9
    Medals
    Join Date
    Apr 2016
    Hatu
    UT
    Posts
    116
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Rep Points
    1
    Did some digging.... hope this helps.
    Exp C-115.pdf
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
